AmitR
Apr 23, 2018NETGEAR Employee Retired
OrbiOS 2.1.4 availability
A quick update. We're about to release an updated version of OrbiOS 2.1.4 in the next few days through our auto-update mechanism for all Orbi models. When it goes live, you should see a prompt in t...
Eric90i
Apr 24, 2018Star
Is 2.1.4 stable? I’m still on 2.1.2.18. Has anyone successfully updated through the app with rbk50 system and then not heard anyone yelling about the WiFi not working?
Apr 24, 2018Guru - Experienced User
If you update to v2.1.4.10 from v2.1.2, you'll need to do a factory reset and set up from scratch. There are major changes which include items in v2.1.3.4 and now v2.1.4.10 which need a good clean slate to start after installed. Others have posted that problems continued after updating to v2.1.3.4, the problems went away after doing a full factory reset and set up from scratch. I've seen this as well.
You should give this a try if you deicide to update.
