AmitR
Apr 23, 2018NETGEAR Employee Retired
OrbiOS 2.1.4 availability
A quick update. We're about to release an updated version of OrbiOS 2.1.4 in the next few days through our auto-update mechanism for all Orbi models. When it goes live, you should see a prompt in t...
BobDuke
Apr 25, 2018Apprentice
The Orbi app offered to update my system this morning. Good way to do it.
The update went smoothly, as have all past updates since I installed in December. I needed to restart the Orbi app to refresh it's data.
I have not needed to do a factory refresh. My configuration had always been transferred automatically through each update. I don't remember all the version numbers, but I started in 1... to 2.0.. to 2.0.?.18 to 2.1.3.4 to 2.1.4.10.
All working well so far.
- tsigApr 25, 2018Luminary
Update mine via the app last night. Very disppointing. No drama at all. After about 5 minutes or so everything was working as normal with no issues at all.
- FURRYe38Apr 25, 2018Guru - Experienced User
Glad the update went smoothly and you haven't had to factory reset. Some haven't had any problems during or after updates. Thats good as well. Factory reset is recommended if you do encounter problems.
Enjoy.
