AmitR
Apr 23, 2018NETGEAR Employee Retired
OrbiOS 2.1.4 availability
A quick update. We're about to release an updated version of OrbiOS 2.1.4 in the next few days through our auto-update mechanism for all Orbi models. When it goes live, you should see a prompt in t...
Eric90i
Apr 24, 2018Star
Is 2.1.4 stable? I’m still on 2.1.2.18. Has anyone successfully updated through the app with rbk50 system and then not heard anyone yelling about the WiFi not working?
Eric90i
Apr 25, 2018Star
Performed the update via the phone app. Went smoothly, no factory reset needed. Things have been running as expected to my knowledge for about 12 hours now.
One side comment, I have never seen my Orbi auto update since I’ve had it. I’ve always either updated when I want or waited for another release.
- loomis1975Apr 25, 2018Luminary
I'm not sure why they are releasing firmware update option via the App and Web UI when upgrade firmware isn't available for ALL devices. You really shouldn't update with only partial firmware available. Updating the router and one satellite (RBR50 and RBS50) and then leaving the RBS50Y and a RBS40 for instance on older firmware is just a recipe for disconnects and frustration.
