AmitR
Apr 23, 2018NETGEAR Employee Retired
OrbiOS 2.1.4 availability
A quick update. We're about to release an updated version of OrbiOS 2.1.4 in the next few days through our auto-update mechanism for all Orbi models. When it goes live, you should see a prompt in t...
WAP
Apr 26, 2018Apprentice
With 3 satellites (1 wifi, 2 ethernet) on 2.1.4 I wasn't able to keep the system up for more than 3 or 4 hours (even after a full reset from scratch). I've only been using 2 satellites (both wifi) for 14 hours and no issues. In my opinion 2.1.4 broke wired backhaul. Going to run on two satellites (wifi) thru the weekend. If it stays up for the weekend I will plug the 3rd satellite back in (with ethernet). Will give progress update after weekend.
Apr 26, 2018Guru - Experienced User
Disable Daisy Chain on the router?
- WAPApr 26, 2018Apprentice
reply to furrye88:
full reset
everything that I can think of is disabled and has been for months.
the following is disabled:
daisy
beamforming
mimu
fast roaming
I'm in AP mode and have selected channel 1 for wifi. Been working great until the latest firmware from two days ago. Been up for 16 hours now but not using ethernet backhaul for satellites.
