AmitR
Apr 23, 2018NETGEAR Employee Retired
OrbiOS 2.1.4 availability
A quick update. We're about to release an updated version of OrbiOS 2.1.4 in the next few days through our auto-update mechanism for all Orbi models. When it goes live, you should see a prompt in t...
mastervisa30
Apr 27, 2018Luminary
Yes Netgear PLEASE STOP AUTOUOPDATES .
Let's us decide if we want to update,stop auto updates and we can use firmware thats working,let us decide if we wwant to update
Retired_Member
Apr 27, 2018
IF NG were to do this, what would be your criteria for deciding when you upgrade?
- RocketSquirrelApr 27, 2018Luminary
Retired_Member wrote:
Let's us decide if we want to update,stop auto updates and we can use firmware thats working,let us decide if we wwant to updateIF NG were to do this, what would be your criteria for deciding when you upgrade?
Coming on this forum and the SNB forum and observing whether early adopters have issues!
I do this with as many items of software & firmware that I can. I remain on Windows 7 in part to avoid forced updates. Recently, Quicken started pushing unsolicited updates and it’s quite annoying.
- Retired_MemberApr 27, 2018
that'll work.....NOT.....there is no way to be sure of those having problems, their network and devices are identical to yours. I've seen some many home network setups on here it makes my head swim. Good luck.
