AmitR
Apr 23, 2018NETGEAR Employee Retired
OrbiOS 2.1.4 availability
A quick update. We're about to release an updated version of OrbiOS 2.1.4 in the next few days through our auto-update mechanism for all Orbi models. When it goes live, you should see a prompt in t...
budy
Apr 28, 2018Luminary
Just updated my RBK40 via the iOS app - it has been a no-thrills experience, as it had been with all other updates, my RBK40 has been through. I am seriuosly thinking, that there must be something going on on the networks, where these Orbis have issues.
This is not to blame anyone of anything and I do think, that NG should be able to address that, but my take on this is… if you haven't experienced these issues with your Orbi, you likely won't, unless something on your network changes dramatically - e.g. getting onto an IPv6 network or where there are multicasts or spanning tree issues involved. Multicast seems to play havoc with mDNS and STP can mess with the mesh setup of your Orbis, resp. their bridges.
RJD
Apr 28, 2018Star
So after over a year of messing about and the past few months of reading all the forums and testing all the firmware releases i have had enough. I now had redundant RBK50 and 2 x RBW30’s costing well over £500 in total let alone the amont of time i have wasted. I pick up my reluctant purchase of Google Wifi today so will report back in a week to let you know my experiences.
The RBR50 on its own works well but only if i split the 5G and 2.4G bands via telnet which used to be an option back on early firmware but for final testing i put it back to single SSID and then stability and connection issues rose again. Turning on any satellte then added more problems with stuff dropping even though showng as connected to a satellite all showing a good 5g backhaul.
Such a shame and for those having good experiences then lucky you. I dont give up on much but after 16 months of hassle enough is enough. Netgear already have my money so it wont phase them as i have no return option.
If Google Wifi causes me similar issues then will continue the pain with the Orbi but if not then a small bonfire may be lit to melt down the most annoying computer related hardware i have ever owned!!!!!!
