AmitR
Apr 23, 2018NETGEAR Employee Retired
OrbiOS 2.1.4 availability
A quick update. We're about to release an updated version of OrbiOS 2.1.4 in the next few days through our auto-update mechanism for all Orbi models. When it goes live, you should see a prompt in t...
cheeky
May 01, 2018Tutor
ARG!!! Now I'm having the same HomeKit issues I was having after the botched 2.1.2.x update. The Home app is expeiencing consistent issues with 'not responding' devices when they are clearly online and connected.
Repeated issues with devices not responding that was only solved after going back to V2.0.1.4. I got to enjoy 2 weeks of blissful stability after you pulled that update. Now you've FORCE AutoUpdated to 2.1.4.10 and I'm having the *exact* same issue.
The inability to control how and when my hardware is updated is a HUGE problem. You have a bug in this firmware that clearly maifests itself after updating OFF 2.0.1.4 and I cannot go back to the last stable firmware version without the damned thing autoupdating nearly immediately after downgrading.
budy
May 01, 2018Luminary
Homekit relies solely on mDNS (aka Bonjour). There are a number of apps available on iOS and macOS, which will tell you which Homekit devices are present on your network. Look for the HAP entries and verify, that the IPs of your Homekit devices are present. If they're not, than something might be blocking the mDNS broadcast on your network.
As far as I can tell, nothing has changed between either 2.1.2.18, 2.1.3.4 and 2.1.4.10 regarding Homekit, but I do have only one Homekit-Bridge on my network.
- ZoneMasterMay 01, 2018ApprenticeSomething MUST have changed in the 2.1.4.x! I updated to 2.1.4.14 last week (& I was probably running 2.1.4.10 just prior to that).
I lost ALL mDNS/Bonjour discovery late last week for the first time ever.- budyMay 01, 2018Luminary
I know that people never should have to do this, since this is the responsibility of the manufactuer, but have you ever tried running tcpdump or Wireshark on your LAN to see, if the Orbi router - when in router mode and I guess this is the reason, I am not experiencing this, is blocking the mDNS multicasts? I know the setting up some probing can be cumbersome, but it may be worth it.
- ZoneMasterMay 02, 2018Apprentice
Correction: I have been running the 2.1.4.10 firmware since last week. Network scan via "Net Analyser" iOS app showed NO Bonjour flags present
I have performed the following additional toubleshooting from my iMac (which is faily distant from my Comcast/ORBI gateways):
- Connect ONLY via my Comcast Wifi Modem:
- Powered off ALL ORBI units:
- Turned on WiFi on my Comcast Router
- Logged in to my Comcast WiFi
- Weak signal & slow upload/download speeds
- mDNS/Bonjour/AirPrint was rock solid
- Network scan via "Net Analyser" iOS app shows Bonjour flags are present
- Connect ONLY via ORBI RBK53:
- Turned off WiFi on my Comcast Router
- Powered on ORBI RBR50 Router
- Logged into ORBI WiFi
- Better signal & faster (but not max) upload/download speeds
- mDNS/Bonjour/AirPrint working. Network scan via "Net Analyser" iOS app shows:
- macOS & iOS seem to reliantly report Bonjour as present
- AirPrint printers (HP & Brother) sometimes don't report Bonjour as present
- Waited
- Powered on ORBI RBS50 Satelite closest to my iMac
- Max signal & max upload/download speeds
- Waited
- Powered on final ORBI RBS50 Satelite
- Everything working
- Waited
While mDNS/Bonjour/AirPrint is still sometimes glitchy. It is working under the 2.1.4.10 firmware after starting the router & satellites in slow sequence.
