AmitR
Apr 23, 2018NETGEAR Employee Retired
OrbiOS 2.1.4 availability
A quick update. We're about to release an updated version of OrbiOS 2.1.4 in the next few days through our auto-update mechanism for all Orbi models. When it goes live, you should see a prompt in t...
Philiposan
May 02, 2018Aspirant
Amit thank you and your team for you persistence in improving the Orbi product and its firmware. I am a new user and installed about 3 weeks ago. I did download the 2.1.4.10 firmware Version for both the main router and the two satellite units. While the system runs beautifully and fast (often over 290 mps) I still am getting problems with drop off of the Internet once or twice a week which requires me to power down the router to get it to reset. Since the new firmware update I have not had to power down and reset my Comcast Wi-Fi modem however and that is an improvement. Is there a possibility that a new firmware update will make the system more stable so it doesn't drop off? Or is there a setting I should consider right now in the system control software to eliminate the problem?
