AmitR
Apr 23, 2018NETGEAR Employee Retired
OrbiOS 2.1.4 availability
A quick update. We're about to release an updated version of OrbiOS 2.1.4 in the next few days through our auto-update mechanism for all Orbi models. When it goes live, you should see a prompt in t...
Retired_Member
May 02, 2018The problem with turning off the auto-update is you are now sitting on the sidelines. Then you have to figure when to jump back in and upgrade your FW and how will you determine that? By reading the posts in here...? Really?
Many of the problems the Orbi has been having can be traced to product diversity. Trying to be all things to all consumers. If FW updates scare you, then perhaps you should try a lower cost basic wifi router.
RJD
May 02, 2018Star
I would gladly like a refund for this rubbish but alas I stuck with it for 16 months. If the firmware was stable and actually worked and didn’t end up making things worse or consistently require resetting everything to then find it still doesn’t work as it should then would be happy with the forced auto updates and the forced single SSID (early firmware allowed a split of 2.4/5G SSID) which was so much better but Netgear removes this and added forced firmware updates which are not stable and do not work (yes yes some people don’t have issues, lucky them). Still not a week yet with Google Wifi but not a single drop or issue with anything. After 2 days or less with Orbi after resets etc etc the issues start again. Just the RBR on its own works well (especially with split SSID’s) but add satellites and boom, total trash at a premium price.
