AmitR
Apr 23, 2018NETGEAR Employee Retired
OrbiOS 2.1.4 availability
A quick update. We're about to release an updated version of OrbiOS 2.1.4 in the next few days through our auto-update mechanism for all Orbi models. When it goes live, you should see a prompt in t...
manuel-c23
May 13, 2018Star
With my RBK40 system, the wired backhaul connection doesn't work if daisy chain is disabled.
Moreover, there's a known issue when you use the wired backhaul and you reboot the router: https://community.netgear.com/t5/Orbi/Bug-Wired-backhaul-Router-reboot-KO/m-p/1568671#M31460
budy
May 13, 2018Luminary
Can't confirm that. My RBK40 runs just fine on wired backhaul without daisy chain enabled.
