AmitR
Apr 24, 2018NETGEAR Employee Retired
OrbiOS 2.1.4 availability
A quick update. We're about to release an updated version of OrbiOS 2.1.4 in the next few days through our auto-update mechanism for all Orbi models. When it goes live, you should see a prompt in t...
budy
May 16, 2018Luminary
You do get the a solid magenta light on the router, when using wired backhaul? If this is the case, this might not be an indicator for a non-working wired backhaul, but simply a bug in the FW of the router.
manuel-c23
May 16, 2018Star
I get the magenta light on the satellite.
- budyMay 19, 2018Luminary
I had that one time, I think… if the satellite is otherwise working, you clould just shut off the LED ring ion the satellite and see if it lights up again…
- manuel-c23May 20, 2018Star
The satellite connection doesn't work, the wired backhaul doesn't recover after a router reboot, you have to disconnect and reconnect the ethernet cable.
- timchMay 22, 2018LuminaryMy wired connection has no problem recovering after power cycling the router.
- cyberprashantJun 03, 2018Luminary
i was having problems iwth 2.1.4.0 suddenly yesterday - kept locking up, couldn't connect ot the router page, no wifi or hardwired internet access - I thought I would have to send it in or what? Setup is RBK53 from costco with 1 wired satellite and 1 wireless. Daisy chain setting was enabled and still left enabled.
Finally did a factory reset and couple of power cycles and syncing the satellites back and seems to be stable now.
- FURRYe38Jun 03, 2018Guru - Experienced User
If you only have 1 Satellite, you can disable Daisy Chain, its not needed if you only have 1 satellite. Try disabling MIMO and Fast Roaming. Try setting manual channels 1, 6 or 11 on 2.4gh as well.
