AmitR
Apr 24, 2018NETGEAR Employee Retired
OrbiOS 2.1.4 availability
A quick update. We're about to release an updated version of OrbiOS 2.1.4 in the next few days through our auto-update mechanism for all Orbi models. When it goes live, you should see a prompt in t...
RocketSquirrel
May 20, 2018Luminary
manuel-c23 wrote:
So we should buy a UPS for the Orbi router because the Orbi firmware is bugged?
No, you should buy a UPS for the modem & router to keep your network alive during a power outage.
manuel-c23
May 20, 2018Star
I don't need that. I just need a fix for the wired backhaul bug after a router reboot.
- JMU1998May 20, 2018Luminary
Is there a beta Firmware available or in the works that addresses the wired backhaul bug?
