thebishop
Dec 05, 2017Apprentice
OrbiOS 2.1 ethernet backhaul - only 10Mbps
Great that ethernet backhaul was just added. Unfortunately, I can't get more than 10Mbps when connecting to the satellite that uses it - neither using a hardwire connected to the satellite, nor using wireless.
Connecting wirelessly to the main router gives a few hundred Mbps over 5Ghz and usually 500+ with a wire. I have previously successfully used the same cables directly and got a 100Mbps link for this remote port...
Have anyone seen more than 10Mbps remotely?
Is there any way I can see which link speed that was negotiated for the sattelite backhaul? Is there any way to tweak the handshake there to ensure I at least get the 100Mbps that should be possible?
Ok, it seems to have to due to the fact that my client device was set manually to 100mbps since previously - changing it to auto detect would give a 1gbps link that seems to work as expected. Let’s disregard this for now until further testing....
1 Reply
- thebishopApprentice
