KouroshMDC
Nov 06, 2019Aspirant
Orbi(RBR50) Keeps crashing / Disconnecting
I have Fios modem and router. Because of this our orbi is set to AP mode. We recently had a problem so my personal IT guy reset the system, updated it to the latest firmware and set it to AP mode, with beaming on. After doing so the Orbi worked great.. or so I thought. It's keeps disconnecting/keep crashing. When it's working its fast and great but every so often my phone or other devices with say "No internet connection" and it eventually disconnects from the orbi. It eventually reconnects. I've read several posts and I'm not sure what to do. One thing I noticed on the Orbi app 2 of my 3 satellites is on a different firmware than the other)V2.3.5.30). The router and 1 of the satellites are on V2.5.0.38 I heard to turn daisey chaining off. Not sure what to do. Does anyone have any other suggestions?
So is the FIOS modem/router still running in router mode? Just checking this here.
Did the IT guy setup a IP address reservation for the RBR in AP mode on the FIOS router?
You need to update the 2 RBS to the save v.38 version which may help fix this. Download the RBS FW files from here:
https://kb.netgear.com/000061363/RBR50-RBS50-Firmware-Version-2-5-0-38
After the RBS have been updated, I would reboot the RBR and Power OFF the RBSs then power the RBS ON 1 at a time. See if this fixed the disconnect problem. I and others are not seeing issues like this with v38 loaded. Working well. A factory reset maybe needed. Try the RBS update first.
- KouroshMDCAspirant
Tried manual updating. Nothing changed. Router(RBR50) V2.5.038, Orbi sat 1 V2.5.0.38 and orbi sat 2&3 are V2.3.5.30. Problem is still happening. I tried turning daisy chain off and applied the update manually.
"orbi sat 2&3 are V2.3.5.30." Need to get these updated as well. All should be on the same FW version.
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected.After updating and I would reset the RBSs. Might try turning off 2 of the RBS and see if the problem still happens with just 1 RBS online. Graduate adding the next one if the problem doesn't appear.
KouroshMDC wrote:Tried manual updating. Nothing changed. Router(RBR50) V2.5.038, Orbi sat 1 V2.5.0.38 and orbi sat 2&3 are V2.3.5.30. Problem is still happening. I tried turning daisy chain off and applied the update manually.
- Anonymous
This is your problem...V2.5.0.38
- Anonymous
