ymc226
Dec 08, 2016Aspirant
Orbit placement with 2 satellites
I have a 3 floor 7000 sq ft home and just bought the Orbi with 2 satellite set from Costco for $500. ISP is Verizon Fios with TV/phone and using the Action Tec Fios Router/Modem which wireless is off as an Apple Airport Extreme is used as an access point to broadcast wifi.
The Orbi router will be at one end of the house (where the Fios cable and modem are) and a satellite will go towards the center of the house. Can the 2nd satellite be place still farther away in a line (R -> S1-> S2) from the Orbi router or should the Orbi router be at the "center." This latter placement pattern would not be how my house built.
ymc226 wrote: Can the 2nd satellite be place still farther away in a line (R -> S1-> S2) from the Orbi router or should the Orbi router be at the "center." This latter placement pattern would not be how my house built.hi
no , atm you have to run the orbi like this
sat ----- router --- sat
as its not a mesh system , there has been suggestion it may be mesh in the future but no real confirmation
so atm the orbi router needs to be in the certer of the 2 units
- ymc226Aspirant
Thanks for your answer.
- bneiderman1Aspirant
What do you mean it is not a mesh system? That is how it was advertised.
bneiderman1 wrote:What do you mean it is not a mesh system? That is how it was advertised.
its not a mesh system in the sat's dont communicate with each ither , they only talk to the orbi router at the current time
