jimcall37
Oct 31, 2017Aspirant
Orbo Satellite blue light keeps turning on then staying on for a while
I have two satellites, but only the one has the blue light turn on. I have reset it, resynced it, but it continues to have this issue. It was in the bedroom, but I switched it out with the one in the dining room so it doesn't disturb us at night. Distance shouldn't have been a factor as it was only 30 feet from the router.
- jimcall37Aspirant
Hi. The sattelite is the RBS50. I have tried multiple times turning it off, waiting, then turning it back on.
- ElaineMNETGEAR Employee Retired
How long have you had the kit?
When did you start experiencing that issue?
Have you tried moving it closer to the main router?
I suggest for you to reset it with a paper clip once again and if that didn't work register the kit in order to log a case.
- jimcall37Aspirant
Hi. I have owned the kit for a little over four months. The issue has been going on consistantly for about a month. I have reset it with a paper clip, but I certainly could try that again. The first time I reset it I had moved it much closer to the router.
