Logo_guy's avatar
Logo_guy
Oribi RBR20 loses connection on a daily basis
Almost every single day I lose internet connection with this router. I call my internet company and it shows no inturruptions on internet and they suggest to me that it could be the 3rd party router. Any suggestions on how to fix this? I also have one ethernet cable connected to the router going straight to my gaming PC.  On another forum I was reading they suggested intel commands, but every time I try something like they suggest the commands are invalid. Any help would be appreciated.
  • FURRYe38's avatar
    Is the Orbi system operating in Router or AP mode?
    What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected. https://kb.netgear.com/000036466/How-far-should-I-place-my-Orbi-satellite-from-my-Orbi-router
    Try enabling Beamforming and MIMO(MIMO may or may not be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
    https://community.netgear.com/t5/Orbi/Most-Stable-Orbi-Configuration/m-p/1941087/highlight/true#M97026
    • Logo_guy's avatar
      Logo_guy
      Okay, that's a lot of info. Let me get it all answered. May take me a bit.
