Adrian97c's avatar
Adrian97c
Apprentice
Oct 01, 2018
Outside WiFi cams ignoring sats & going to router?
I just got a rbk23 kit (1 rb20 router & 2 sats), my house is 2000sqft single family, my outdoor wifi cams(1 on each corner -4total) are 2.4/5ghz WiFi... They keep connecting to the router in middle of home instead of the 2 sats on each opposite side of house. My orbi setup is default settings (daisy, mimmo, etc all enabled), most recent FW, and layout is (Sat, Router, sat) with about 30-50ft from each other, with the middle being the router. I know a 6k sqft system is overkill, but my outdoor cameras struggled to connect with my R7000. so I thought an Orbi would help me... now I’m struggling with the Cameras connecting to the middle (router), instead of the satalites right next to the cameras!
  • FURRYe38's avatar
    Alot of signal handling is done at the camera as well. It all depend on what they are set up and configured for in handling wifi signals.
    What you might try is to reduce the power levels on the router from 100% to say 75 or 50% and see if the cameras connect differently. This may impact signals between the router and satellites as well.
    Try setting manual channel 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz.
    MIMO, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
    • Adrian97c's avatar
      Adrian97c
      Apprentice
      I will disable what you suggested, but some questions:
      Where do I go to “lower the strength”?
      What the best way to determine which 5ghz isn’t being used? It’s set to a number like 48, there was like 4 choices to pick from.
      • FURRYe38's avatar
        Adanced Tab/Advanced Settings/Wireless Settings
        Try them all. However use a wifi scanner to see other neighbors near by to see what there using. Should matter for cameras. I presume they are only using 2.4Ghz?
  • Seems that your cameras do not support roaming and they just connect to the first basestation that becomes available (which is the router) and never makes measurements to decide if there are better basestations to roam to. Check if the cameras support (802.11k/802.11v/802.11r)
    - Try switching off a camera and then switch it on and see where it will connect.
    - Try switching off the router for few seconds and then on to see if the cameras will decide to change to the satellites.
    It can also be that the cameras don't like the 5GHz channel that you set in the router (because it's used by neighbours) and goes for the 2.4 GHz channel.
    - Try changing the 5 GHz to another channel as suggested by FURRYe38.
    - Try also to reduce the power of only the 2.4GHz channels to very low value and see if the cameras will behave differently.
      Adrian97c
      Apprentice
      Model: ADC-722w
      All it says on data sheet around WiFi: 2.4ghz/5ghz, B,G,N,AC.
      I lowered power on both 2.4/5ghz, so let me put the 5ghz back to 100%.
      Thx for the advice, will be trying all suggestions, not giving up easily... I was excited to try Orbi, so I did expect some placement & settings tweaking would be required. Will keep you all posted.
      Adrian97c
      Apprentice
      I took all of furrys advice, lowered 2.4ghz to 75%, but kept 5ghz full strength... disabled all the Items he listed.
      So far entire day since then, all is working good!
      I’ll experiment with adding back roaming for few days... & then adding back beamforming, then mimmo, etc.
