Carnaged's avatar
Apr 23, 2017
Page Timeouts, streaming issues?
Hi,
I bought this system on Wednesday and I am getting the coverage that I wanted which is great but I am having some weird timeout problems with the internet that wern't present before, this is on my IOS devices and I can see that there have been mention of issues with IOS on this system. Let me clarify, i'm not having full disconnects, its just pages timing out, however when watching videos back from my remote Plex server I am having issues as well with buffering which did not happen before.
My wifi connection is full and connected when this happens, for the timeouts usually a refresh sorts those out, as for the Plex issues, as most of the stuff I watch is direct playback it needs to have a solid connection and any interruption affects the quality.
My Orbi units are not overlapping too much as one is in a summerhouse and the other is in the house, opposite end.
Any thoughts?
    Sounds like you might need to move your Orbi router and satellite units closer together, or place them near a window to get better signal.  The satellite units need to maintain a solid 5 GHz backhaul connection to the router, or you will experience problems like you describe.
    • Carnaged's avatar
      Carnaged
      Tutor
      This is happening when I'm using the router inside with a good wifi connection. I have disabled IPv6 in case that is causing an issue. I don't think it's the distance that's the issue
      • st_shaw's avatar
        st_shaw
        Master
        No way to tell unless you provide more information.  Need to know where the router and satellite sit, how far apart, where the problem client is relative to router and satellite.  You also need to check whether the problem client is connected to the router or satellite when the problem occurs.
        Your client could have have a perfect WiFi connection to the satellite, but if the connection between satellite and router is poor you will have issues.
        Please provide some more details so someone can help you.
