DENNISO
Dec 30, 2018Follower
Painting outdoor satellite
Can you paint an outdoor orbi satellite to blend in with the house?
Dec 31, 2018Guru - Experienced User
If you paint, i would use a spray paint. Just understand that if you do paint the unit, this may void warranty as if the unit would need to be returned due to a future problem, I don't think NG would accept it back due to a change in color and paint job. :smileyfrustrated:
