tripleg
May 31, 2019Aspirant
Pandora won't stream
I just installed an Orbi system with 2 satellites yesterday. Now when I try to play Pandora via WiFi, it queues up a song, never plays and instead cycles to the next. ad infinitum. I've already rebooted everything including my AT&T 210 modem (gigabit fiber). It will stream fine if I turn the AT&T wifi back on and turn off Orbi, anyone seen this problem.
Try option 3 then.
tripleg wrote:I'm not able to use IP passthru as I have that already dedicated to another system that requires a WAN IP. Therefore if this is the only way it will work then I will need to return this product as it won't work
Modem Combo Units:
This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
1. Configure the modem for transparent bridge mode. Then use the Orbi router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
tripleg wrote:I just installed an Orbi system with 2 satellites yesterday. Now when I try to play Pandora via WiFi, it queues up a song, never plays and instead cycles to the next. ad infinitum. I've already rebooted everything including my AT&T 210 modem (gigabit fiber). It will stream fine if I turn the AT&T wifi back on and turn off Orbi, anyone seen this problem.
- triplegAspirant
