jvanstone12
Aug 23, 2016Tutor
Parental / Device Controls
Will this device include Parental / device controls in the backend? A router without it is useless in our house, as during homework times we have to control who uses the internet at what times for th...
andreapdx
Jan 03, 2017Aspirant
Did you get an answer to your question? I want the same functionality but can't figure out a way to do it.
Thanks.
jvanstone12
Jan 03, 2017Tutor
Sorry,
I ended up purchasing a Linksys AC3200 router instead, so I'm not able to answer your question. With the Linksys I am able to login using the Android app and set usage times per device.
