jvanstone12
Aug 23, 2016Tutor
Parental / Device Controls
Will this device include Parental / device controls in the backend? A router without it is useless in our house, as during homework times we have to control who uses the internet at what times for th...
jvanstone12
Jan 03, 2017Tutor
Sorry,
I ended up purchasing a Linksys AC3200 router instead, so I'm not able to answer your question. With the Linksys I am able to login using the Android app and set usage times per device.
andreapdx
Jan 03, 2017Aspirant
Thanks for the info. I might end up returning the ORBI and doing the same thing. Parental Controls and access time control should be standard in a home router and using OpenDNS just is not on par with what is out there. Apple has had this feature for a decade...sorry they are leaving the wifi router market.
