dchbbc
Oct 27, 2018Apprentice
Password Reset
Hi
I am trying to reset my password on my Orbi Router. I tried the PW that I thought I used and it said no. I tried the PW on the router and it said no. I tried to answer the questions to reset it and it said they were wrong (My first NETGEAR product...Orbi and my sister's name....I think I would know that). I don't know what else I can do.
I have my guest network disabled (My network name is DavidHome) and in my list of networks I'm seeing DavidHome-Guest with no password protection on it. It was never there before and I never set one up. So I'm trying to access the Orbi online to see if there is something set there that I don't know about.
Hi dchbbc
Welcome to NETGEAR Community!
You may have to factory reset the router for you to access the settings page.
It appears that the latest firmware defaulted the Guest network to turn on. This was also observed by other users. To resolve this, we would have to access the Orbi settings page and disable Guest network.
Blanca
Community Team
- Blanca_ONETGEAR Employee Retired
Hi dchbbc
Blanca
Community Team - BabyButts3AspirantI don’t know how to manually reset my password
BabyButts3 wrote:
I don’t know how to manually reset my passwordWhat's the device you need to reset?
Look on the back.
Is there a little hole labelled Reset? If so, insert the end of a paperclip and press for about 10 seconds.
That puts the device back to its "out of the box" state. Then you can set it up from scratch.
- DSweatyBInitiate
On Firmware V2.2.1.210
Product RBR50
Why is it asking me for my sister (which I don't have one) and first netgear product (who remembers that)?
I have over 20 devices connected. I really have to reset my router to gain access to orbilogin.com?
Please tell me the smart people at Netgear came up with a solution by now.
