PhantomMarth
Aug 28, 2020Aspirant
PC Satellites Ethernet Speed is same as Iphone Wifi Speed
This has really been bothering me for months now. Ever since I've move to this house I purchase the RBR40 with the router and 2 satellites. I needed this because my modem is in the basement and I do not get any good connection when I'm upstairs. I decided to buy the router connect it to the modem, as well as put 2 satellites upstairs. One satellites is in the back room which is fine for outdoors since no one needs it for ethernet speed. But the one I have setup next to my PC is connected through ethernet. Countless times I have tried to look into the problem and troubleshoot. For these past months, I cannot find a solution for why the speed is so poor. I understand since the satelitte is wireless and not connected to the router my speed will not be near what I pay. But, I do not understand why the ethernet speed is the same as my IPhone WIFI speed. I have tried everything from fixing settings and factory resetting the router, to purchasing a couple new ethernet cables. Please help! Thanks in advanced to anything that reads this!
- MstrbigMaster
Go to orbilogin.com and check your settings
Make sure you are on a WIFI channel with less traffic on it. You can check this with a program like NetSpot.
Under Advance > Advanced Settings > Wireless Settings Uncheck "Enable 20/40 MHz Coexistence" and "Enable Daisy-Chain Topology", Check "Enable WMM (Wi-Fi multimedia) settings", "Enable Implicit BEAMFORMING - Boosts WiFi speed, reliability, & range for all mobile devices" and "Enable MU-MIMO"
- PhantomMarthAspirant
I just did that. After I restarted router, I still get the same speeds. My Iphone get 380 and so does my pc.
- MstrbigMaster
Is the network cable connected to your PC cat5 cat5e cat6? If cat5, try at least cat5e.
