cwkal's avatar
cwkal
Performance spikes
Hi. Just set up my orbi mesh network. I am not getting great performance across the satellites-- performance drops off quickly with even a short distance. I am in a city with a lot of interference. One thing I am seeing is a lot of spikiness in performance. My wifi speed looks like an ekg.  I don't see the same spikiness in the noise on the network (I am using Mac's wirelss performance scanning). It's just the rate that is jumping around.
Any thoughts about what might be causing the up and down network speed?
Thanks.
-Chuck
  • What does the Orbi speed test show in the browser GUI? Have you configured anything in the GUI yet?
    • cwkal's avatar
      cwkal
      Do you mean at routerlogin.net? I don't see any wif speed information there. The setup app shows 900 Mbs- which is the speed at the router as I understand.
      • Mstrbig's avatar
        Mstrbig
        Master
        yes or orbilogin.com - Advance - Setup - Speed test
  • FURRYe38's avatar
    What channels are you using?
    Also try turning down the power output of the RBRs wifi radios from 100% to 50% and see if this changes anything. Under Advanced Tab/Advanced Settings/Wireless Settings
    Thanks.
    -Chuck
    • cwkal's avatar
      cwkal
         V2.5.1.16
      What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too? I have a Nighthawk 32 cable motem attached.
      What is the size of your home? Sq Ft? About 1500 sq ft and less than 30 ft between devices. Through some walls though.
      channel 48, but it looks like I only have choices of a few. My performance scan suggests others.
      Any Wifi Neighbors near by? If so, how many? Yes, lots
      Also try turning down the power output of the RBRs wifi radios from 100% to 50% and see if this changes anything. Under Advanced Tab/Advanced. Thanks I'll try this. Seems paradoxical to turn the power down, but let's see what happens..
      • FURRYe38's avatar
        Is there a different model # for the modem? Like C#### or CM#### or D#### or DM####?
        Having lots of nieghbors near by can cause problems. This is call wifi congestion. So in some cases reducing the power output of your system to reduce the wifi foot print and help reduce external wifi interferences helps in some cases. You don't always have to broadcast full power.
        cwkal wrote:
           V2.5.1.16
