MarcoBru
Mar 01, 2020Tutor
performances RBK53 - pretty poor
In this we I installed my brand new RBK53, as substitusion of my previous network based on apple airport.
I've different floor to cover with my network.
I placed 1 satellite on the mezzanine, router in living room, other satellite in the lower flow perfectly below the router (linear distance maybe 3 meters)
I'm very upset of the bad performances, definetly WORSE than the apple devices.
The signal for the satellite in the lower flow are indicated as "not sufficient", sometimes the led turns on yellow.
Is there some option that I can fine tune or it is better to repack these toys and send back to amazon?
thanx!!
Is the Orbi system operating in Router or AP mode?Is the Orbi system a new or refurbished unit from Amazon?
What is the distance between the router and satellite(s)? 30 feet is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected. https://kb.netgear.com/000036466/How-far-should-I-place-my-Orbi-satellite-from-my-Orbi-routerWhat channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz.
Any Wifi Neighbors near by? If so, how many?Try enabling Beamforming and MIMO(MIMO may or maynot be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).- MarcoBruTutor
thank you for your thorough support!!!
Answers:
What Firmware is currently loaded? last one, I did the update after installation
ISP modem I don't know these data, but my connection is 30MBs. My claim is however for the internal network speed, and mostly lack of network coverage
Orbi system operating in Router and NEW
Any Wifi Neighbors near by? Yes One + guest
thanx for the hints, I'm going to test this evening!
In the meanwhite, that's the status
As I wrote, distance between router and satellite 2 is 1 floor, 3 meters in vertical.
MarcoBru wrote:thank you for your thorough support!!!
Answers:
What Firmware is currently loaded? last one, I did the update after installation. To confirm, v2.5.1.8?
ISP modem I don't know these data, but my connection is 30MBs. My claim is however for the internal network speed, and mostly lack of network coverage. Test both wired and wireless speeds?
As I wrote, distance between router and satellite 2 is 1 floor, 3 meters in vertical. 30 feet is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
