greys4u2
May 14, 2018Aspirant
Pinkk Light
My Orbi modem and my router are about 5" from each other, the Orbi is hooked up to my stereo system, what is the pink ring at the top, is anything wrong?
greys4u2
This my system, do you need the serial number
DarrenM
May 15, 2018Sr. NETGEAR Moderator
Can you be more detailed on the issue you are having? also what model orbi do you have?
DarrenM
- greys4u2May 15, 2018Aspirant
You have the model from a previous post, my question is about the ring on the Orbi, its pink and I want to know if its safe or is something wrong
