ransonrjr
Oct 10, 2016Follower
Placing Orbi Satellite in attic
I am contemplating placing my Orbi satellite in the attic. Does anyone know what the Orbi's tolerance is for heat?
- Oct 10, 2016
You technically could put it in the attic and it will run fine. In my experience with the Orbi, it runs very cool and since most of the heat rises out from the top with not very much obstruction it should do ok. The only misgiving I have is that in the hot summer months, the attic will get pretty hot and although the Orbi may be able to take the heat, it will eventually shorten the life of your unit.
k9kids
Oct 13, 2016Guide
Plastic doesn't do well under extreme heat. I'd worry about the enclosure warping.
peteytesting
Oct 13, 2016Hero
i would be far more worried about the thermal stress the heat and dust would cause to the cpu and its lifespan
