th3w01f
Jun 03, 2019Apprentice
Please expose the ability to use separate SSIDs for 2.4Ghz and 5Ghz on Orbi!
This is becoming rediclous since the functionality is already there. I've been an Orbi user for about 2.5 years now and I'm to the point where I'm going to have to find another solution. I'm coveri...
Jun 07, 2019Guru - Experienced User
Overall it's up to NG to offer the support or not. If they don't then thats up to NG. It is what it is. If users don't like the fact that NG doesn't offer SSID separation support, then user need to find another Mfr that does.
Good Luck.
th3w01f
Jun 08, 2019Apprentice
I agree completely, I work closely with Product Management and Engineer at an enterprise software developer and if people don’t ask it will never get done. I’ve seen features that weren’t even on the radar get finished in a single dev cycle due to customer feedback.
Again I have no idea why 2.4 is so bad in my house with almost no interference but the backhaul speeds from the satellites are great. This brings up another issue I need to troubleshoot. Why is a 5G connection to a Satellite so much slower than the same device connected to the router, when the backhaul between the satellite and router is good.
- sclawrencOct 01, 2019ApprenticeI agree with the OP.
Too many people have asked for this ability to separate the ssid for each band for Netgear to ignore.
How many people does it take to actually get a feature request implemented?
