12345_12
Aug 26, 2019Aspirant
Please Help - Orbi RBR50 - assigning frequencies - splitting freqencies
Can you help ? I have a Orbi RBR50 with 3 satellites. All are wired. I am using a BT modem but have switched off the wireless so only the Orbi is broadcasting. I cannot connect to older devices. I ...
Aug 26, 2019Guru - Experienced User
You can also temporarily disable the 5G SSID broadcast while setting up these 2.4Ghz devices. Under Advanced Tab/Advanced Settings/Wireless Settings. This should work for getting these devices connected.
Splitting of SSIDs on Orbi is not officially supported.
I cannot connect to older devices. I have the read the previous strings (some of which are very passionate) and I need to be able to split the wireless signal. The issue is arising because my iPhone X is on the 5ghz channel and the older devices are on the 2.ghz so although they can connect to the wireless, if the set up requires an app on the iPhone then the app, router and device aren’t talking to each other ?
How can I suppress the 5ghz channel long enough to connect all the devices (Sonos/Nest) etc
I am not a computer whizz so simple instructions would be gratefully received ? Many thanks.
12345_12
Aug 27, 2019Aspirant
Many thanks to both responses. I tried both and some units connected but i still cant get the Sonos to connect. I will try Sonos directly. Thankyou
- FURRYe38Aug 27, 2019Guru - Experienced User
Can try this as a quick temporary test, disable WPA on the Orbi. See if the SONOs connects. If it does, then try WPA and TPIK and see if it connects. Last mode would be WPA2 and AES only...
- Retired_MemberAug 27, 2019
12345_12 wrote:Many thanks to both responses. I tried both and some units connected but i still cant get the Sonos to connect. I will try Sonos directly. Thankyou
https://community.netgear.com/t5/Orbi/Sonos-can-t-connect-to-Orbi/td-p/1695787
