eternaleigh
Mar 31, 2020Aspirant
PLEASE HELP with RBR20 maximizing upload speeds
I currently have an orbi mesh system with router (RBR20 - firmware V2.3.5.30) with 2 satellites (RBS20 - firmware V2.3.5.30). My internet speeds are sh*thouse to say the least but its the best i can ...
Mar 31, 2020Guru - Experienced User
What is the Mfr and model# of the ISP modem/ONT the NG router is connected too?
Above suggestions working:
https://community.netgear.com/t5/Orbi/Throttling-Devices-RBK53/m-p/1858561/highlight/true#M81925
https://kb.netgear.com/31486/How-do-I-reset-my-Orbi-system-to-factory-default-settings
Try this to get your ring door bell to connect:
https://community.netgear.com/t5/Orbi/v2-5-0-38-undoes-SSD-split-is-there-a-fix/m-p/1816546/highlight/true#M73951
https://community.netgear.com/t5/Orbi/orbi-20-cannot-connect-Swann-Camera/m-p/1822475/highlight/true#M75403
- Retired_MemberMar 31, 2020
FURRYe38 wrote:What is the Mfr and model# of the ISP modem/ONT the NG router is connected too?
What is the distance between the router and satellite(s)? 30 feet is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected. https://kb.netgear.com/000036466/How-far-should-I-place-my-Orbi-satellite-from-my-Orbi-routerWhat channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz.
Any Wifi Neighbors near by? If so, how many?Try enabling Beamforming and MIMO(MIMO may or maynot be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Set Short preamble instead of Long preamble modes. Save settings and reboot the router and satellite(s).Above suggestions working:
https://community.netgear.com/t5/Orbi/Throttling-Devices-RBK53/m-p/1858561/highlight/true#M81925Has a factory reset and setup from scratch been performed since last FW update?
https://kb.netgear.com/31486/How-do-I-reset-my-Orbi-system-to-factory-default-settingsTry this to get your ring door bell to connect:
https://community.netgear.com/t5/Orbi/orbi-20-cannot-connect-Swann-Camera/m-p/1822475/highlight/true#M75403:smileysad:
