Misses
Jan 24, 2020Follower
Plug in satellite
I recently purchased an Orbi AC3000 and would like to know which plug in satelite would work with it. The only one I find says it works with AC2200. Please advise.. Thank You :)
All the satellites are compatible.
- plemansGuru - Experienced Userwith that version anyway. Not quite the same if you had the AX Orbi.
Orbi AC satellites are not compaible with Orbi AX currently. NG is supposed to make them compatible. I believe some of them and not all. No time frame on when this will happen.
