englemt's avatar
englemt
point to point distance
I am considering buying this for my father.  He has a garage that is about 120 feet away from his house.  I can put both Orbi's in a window and they will have line of sight.  Do you have any guidance on this type of distance and going through standard single pane glass?
Thanks!
  • Glass is not your friend, (deflector) in wireless environments.  And, the distance may also be an issue. If you decide to try, make sure you that you can get a full refund, if it does not work out.. If at all possible, consider an outdoor Access Point, with a proper outdoor Ethernet cable buried..
  • as long as the glass windows are not tinted there shopuld be little issue ( tinting contains metal film ) the distance shouldnt be an issue here
    a simple test with your current wireless router located at one window and a laptop at the other window
    if you get pretty good connectivity with the test above than the orbi should work fine
    pete
