TottenhamNJ's avatar
TottenhamNJ
Poor Network Quality
Ive got the Orbi RBR 20. Set it up last weekend and haven't had any issues. Today, I had issues with poor network quality. Even got a message from Microsoft Teams that my network was causing poor call quality. Swapped around the satellites so that the 5ghz is in the same room I am - 2 feet away. Get on another call and the same thing happened. Am I better off using the Orbi in AP mode?
  • FURRYe38's avatar
    https://community.netgear.com/t5/Orbi/Most-Stable-Orbi-Configuration/m-p/1941087/highlight/true#M97026
    • TottenhamNJ's avatar
      TottenhamNJ
      Seriosuly?
      Firmware V2.5.1.16
      Dont know the router manufacturer, it doesnt say
      Size of the house isnt the issue I am in the room directly above where the Oribi router is.
      No idea what channels Im using or how to change them
      Im in a neighborhood, so yeah a bunch of other wifi around
      No clue what "beamforming" is or anythign else you've asked
      • FURRYe38's avatar
        You might want to get a friend, nieghbor or family member to help you out with this...
