Fieldstone's avatar
Fieldstone
Poor service
Installed Rbr50 today using AT&T service fiber optics of 500 mbps. Have an upstairs bedroom that before I installed the Orbi speed was around 30-40 mbps. Once I had At&T put my combination router modem into pass through mode, the speed hit 180 mbps. Since then the service is back down to 30-40 mbps. Does anyone have any suggestions or ideas of what needs to be done.
  • plemans's avatar
    Have you checked to see if your device is connected to the 2.4ghz or the 5ghz? 2.4ghz is a slower network but broadcasts further and through more materials.  And the orbi does band steering. That allows devices to switch between the 2.4ghz and 5ghz as needed. Maybe you're device isn't needing at much bandwidth.
    And 40mbps is enough for even streaming 4k
    • Fieldstone's avatar
      Fieldstone
      I'll look into your suggestion and advice thank you. I will say I'm paying AT&T for 500 mbps and I purchased the Orbi system at considerable cost, in my opinion extra cost that should not be needed. So I hope you will agree if I get 50 mbps upstairs that means I'm getting 10% of the amount of mbps I'm paying for. That in itself does not sit well with me and indeed makes me very frustrated and angry at this whole system, and expense. I understand going thru walls and upstairs will not yield me 500 mbps, but getting only 50 or 40 or even down to 30 sometimes, is just not right.
      • CrimpOn's avatar
        CrimpOn
        I agree that 50mb does not sound reasonable when the ISP is delivering 500mb.
        It would help to know more details about the installation.
        • Has the AT&T speed been verified by connecting a computer directly to the AT&T box with an ethernet cable and running a speed test?
        • When the Orbi RBR50 router is connected to the AT&T box, what speed does the router report?
        • The Orbi is usually sold as a package consisting of one RBR50 router and one or more RBS50 satellites.
          Is this what you have?
        • If there is a satellite upstairs, what does the Orbi system report about the link between router and satellite?
          (5G? Good?)
        • How does the device being used to measure this 50mb speed describe the Orbi WiFi link?
          2.4G? 5G? Link Rate?
