drdoz's avatar
drdoz
Apprentice
Jul 15, 2018
Port 8080 blocked
Tried to use a speed test website and it told me port 8080 was blocked.  Nothing in the Orbi configuration looks relevant to fixing this.
  • FURRYe38's avatar
    What FW version are you using?
    What browser are you using?
    What is the Mfr and model# of the ISP Modem the Orbi is connected too? Built in router here by chance?
    Wired or wirelessly connected when doing speed tests with a PC?
    • drdoz's avatar
      drdoz
      Apprentice
      Thanks for the reply!
      FW: 2.1.4.16
      Browser: Safari
      Netgear CM500 Modem has no built-in router
      wireless succeeds, wired fails (weird)
      • FURRYe38's avatar
        Same PC via wired? Try different wired PC?
  • wired or wireless, I can't connect to fast.com
    also: appletv can't get netflix
    computer also can't connect to netflix
    wtf?
  • FURRYe38's avatar
    AH, Didn't know you had circle enabled. This could be the cause if not correctly configured. :smileyfrustrated:
