Lijo's avatar
Lijo
Port Forwarding / Port Triggering
Loading the page for Port Forwarding / Port Triggering fails with an error.
Uncaught SyntaxError: Invalid or unexpected token
forwarding.htm?model…ersion=V2.7.5.6:145 Uncaught ReferenceError: master is not defined
forwarding.htm?model…ersion=V2.7.5.6:178 Uncaught ReferenceError: forward_array_num is not defined
forwarding.htm?model…ersion=V2.7.5.6:263 Uncaught ReferenceError: master is not defined
VM94 forwarding.js:1 Uncaught ReferenceError: lan_ip is not defined
Any help how to fix this issue would be appriciated.
Re
gards Jörg
  • FURRYe38's avatar
    How are you configurng the Port Forward or Trigger? What port numbers are you using?
    What browser are you using?
    Did you first disable uPnP before configuring PF?
    The Orb AC series is EoL so may not see any fixes. You should give 3rd party FW Voxel a try.
  • After a factory reset all starts working as expected and all errors are gone.
    • FURRYe38's avatar
      So this resolves the issue your seeing?
      If so, be sure to make a new backup configuration to file for safe keeping.
      Mark your answer as a solution so others know.
