Trojan81
Sep 27, 2017Aspirant
Port Forwarding for Cameras behind ATT Router in IP Passthru
Hi Everyone,
So I have ATT Fiber service using the Pace 5268AC modem in passthru mode (this modem is not capable of bridge mode) plugged into my orbi system. The Orbi is in DMZ from the ATT router and my home runs everything thru the ORBI. The ORBI is also in Router mode distributing IPs to all devices. My camera system requires port 80 and 6036 to be open in order to remotely monitor my Outdoor cameras. I have done everything required in the port forwarding settings to accomplish this, but those ports will not open and I cant access my cameras remotely. Any help or suggestions would be greatly appreciated!
What port forwardings do you have setup? You should be able to port forward 80 and 6036 on the Orbi to the camera's Orbi-assigned IP as normal, also port forward 80 and 6036 on the ATT router to the Orbi's ATT-assigned IP address. Then from the outside port 80 and 6036 should go to your camera.
You could remove Orbi from the DMZ and switch Orbi to AP mode. Then manage forwarding from the ATT router.
