Darryl66's avatar
Darryl66
Port Forwarding kills internet on Orbi
Hi
I am having issues setting up port forwarding on my Orbi router, what happens when I set the port forwarding rule up the internet stops working delete the rule and the internet starts working. The rule I am setting up is a port 8080 to an IP address on me network
The set up I have is VM Router in Modem mode Orbi 50 running with one satalite I have checked for double NAT and there is not one I only get the router IP when doing a tracecert
  • FURRYe38's avatar
    Both wired and wireless internet access goes down?
    How do you have Port forwarding configured?
    Did you disable uPnP before setting up any PF rules?
    Darryl66 wrote:
    Hi
  • It is the latest firmware as just down loaded when trying to configuare
    set up is just a simple add custom rule port 8080 no special configurations all default likewise default settings on router
    • Darryl66's avatar
      Darryl66
      Sorry meant to add wireless and hardwire who use hard wire what’s a wire 😀
      • FURRYe38's avatar
        Please try a different port, say 8181? Same thing?
