CarlE123's avatar
CarlE123
Port forwarding not working
Hei have been trying to port forward my router so me and my friend can play call of duty bo4 together, but it doesn't seem to work
  • CrimpOn's avatar
    CrimpOn
    The most common problem involving internet gaming is having a "Double NAT" situation, where the Orbi is in "router" mode and connected to an ISP device that is also a "router" (in addition to being an internet modem.)  Netgear describes a Double NAT in this web page:
    https://kb.netgear.com/30186/What-is-Double-NAT
    Notie the link at the bottom on how to fix it.
    What is this Orbi connected to? (brand, model)
    • CarlE123's avatar
      CarlE123
      I think you are right. My modem is not in bridge mode so I will try and turn it to bridge mode later
  • FURRYe38's avatar
    This would be a double NAT (two router) condition which isn't recommended.
    Couple of options,
    3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
    • CarlE123's avatar
      CarlE123
      i set my modem to bridge mode but its still not working tho
      • CrimpOn's avatar
        CrimpOn
        Probably worth a minute to double check that the Orbi router "internet address" matches the public IP address reported by any of the port scanning web sites, such as Gibson Security "Sheild's Up!": https://www.grc.com/x/ne.dll?bh0bkyd2
