Mkstretch
Jun 13, 2020Aspirant
Position advice
I have the rbr20 with 2 satellites. I'm only using 1 satellite at the moment.
I believe the satellite is about 40ft or so away from the router on the second floor. The router is on my main floor(1st floor). Would it be better to put my router on the 2nd floor and put my satellite on the main floor? I was also thinking about hooking up my other satellite in my garage which would be about 45ft or so from the router on my main floor and about 20ft from my second floor satellite. Thanks guys!
my house is 3900sq ft.
1 Reply
Either would work. Just as long as you dont put the RBR in a basement.
