SchaferEver
Jan 29, 2025Aspirant
Power supply for RBR50
Hello,
Recently moved from a region where the power tension was 127 to a new region that is 220.
All my orbi router and satellite have a power supply of 127. I am wondering if I can swap the power adapter to a generic 220, 12V and 3.5a (same V and A from 127) and still have the router and satelite working fine ?
Today I am powering them thru a transformer, but want to take that gear away and mount the satellite higher in the wall.
Thank you
Yes, any power supply that provides 12v/3.5amps will work as long as it has the same dimension/polarity plug and the electrical plug is compatible with the locality.
I would start with an Amazon search.
- SchaferEverAspirant
Thanks Sir!
