alokeprasad
Nov 28, 2020Mentor
Powerline PLP2000 wired backhaul for RBK50 or not?
Thinking of buying the RBK50 this season. The office room has the cable modem and will have the RBK50 base router. It will have one Powerline PLP2000 connected to the RBK50 base router (with PLP...
Nov 28, 2020Guru - Experienced User
many things impact both powerline performance and wireless performance.
What I'd do? try them both and see which one works better.
We can't say 100% which will work better based off the details you gave.
alokeprasad
Nov 28, 2020Mentor
Thanks for the reply. You are correct that there's no way of knowing without trying it out.
Can I set the satellite up for wired backhaul, test the speeds, and unplug the ethernet wire for it to switch to WiFi backhaul automatically?
Or do each: wired, wireless backhaul: have to be set up individually?
- plemansNov 28, 2020Guru - Experienced User
You should be able to.
i used to frequently move my satellites around and some would be hardwired some wireless and didn't have to reinstall any of them.
- FURRYe38Nov 28, 2020Guru - Experienced User
I recommend trying a search here on he power line or PL, there as been a few posts about PLs working with Orbi with wired backhaul in the past I believe.
- alokeprasadNov 28, 2020Mentor
I reluctantly invested in PLP2000 because of WiFi connection issues in my living room with my aging R9000 X10.
Hopefully, RBK50 satellite using wireless backhaul in the same room as my TV, receiver, Hopper etc will be stable and fast.
I can still use a few low bandwith and older devices in that room with my PLP2000 (and a switch) to take some of the load off the Orbi connections. Other rooms typically have newer devices that would be OK with the Orbi.
The only thing keeping me from getting the Orbi is potential headaches in using 2.4 GHz Ring devices w the Orbi.
Aloke
