mike_spooch's avatar
mike_spooch
Initiate
Feb 09, 2020
PPPoE with Centurylink 1G FTTH
the CL supplied router uses PPPoE and the status shows the WAN port is tagged. I do not see where I can tag the WAN port with the ORBI... is this possible??
thx,
-mike s
    • mike_spooch's avatar
      mike_spooch
      Initiate
      thanks liquidcore. to add some additional info.. when I originally looked at the VLAN section in advanced, it appeared to only apply to the LAN ports, at least for the "by bridge group" section. however selecting "by VLAN tag group" it worked for the WAN port. also note Centurylink expects VLAN tag 201.
