AlainDeMan
Dec 05, 2025Follower
Printer behind ORBI not found
Dear friends, I have a standard configuration, with a WiFi modem from my Telco provider in the basement, and an (RBR50) ORBI access point (set-up as Router) in my kitchen. Both have a different S...
Dec 05, 2025Guru - Experienced User
Make sure the printer and the printers app on the mobile device are connected on the same network. Either on the ISP router or Orib router system.
If your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router.
https://community.netgear.com/kb/en-orbi-knowledge-sharing/static-ip-address-configuration-for-ap-mode/2456256
https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Try option #2 first...
Be sure to contact the printer Mfr for additional help and support for there product.
