75aces
Dec 04, 2019Initiate
Printing issues -RBR50
Newbie here.
Found a solution to my problem and maybe it will work for others too.
I recently purchased Orbi RBR50. The product works as advertised. Until, I realized that my printer was not communicating with my computer.
I deleted the printer from windows and reinstalled. That didn't work. Used both Lan port and TCP/IP to no success.
Then, I decided to try one last thing. My cable modem/router. Used the WPS setting in my printer and pressed the button on the modem. Oh, before I forget, you have to turn on the broadcast at routerlogin.net. It won't work if it's not broadcasting. It should work if your printer doesn't have WPS.
Hope this helps someone else.
- ekhalilMaster
From your description I get it that your Orbi is set in AP Mode, correct?
- 75acesInitiateThe only 2 setting changes I made was I went to the highest security protocol and turned off the 5ghz setting. The reason I turned off the 5ghz setting was because of some devices I have can only communicate at 2.4ghz.
