bgeiser286
Aug 29, 2018Follower
Problem with Orbi RBR50 since FW upgrade 2.1.4.16
This router is a direct connect to a feber network; there is no modem.
My normal wired and wireless speeds are usually in the range of 95+ Mbps download and 50+ Mbps upload.
I upgraded th...
Aug 29, 2018Guru - Experienced User
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials.
MIMO, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
Has a full power OFF for 1 minute then back on of the system or a factory reset been performed on the system and setup from scratch? Others reported having to do this and there system worked better after the reset...
Orbi
Oct 20, 2018Star
I am having the same exact problem, downloads are slugish but the upload is zero. This firmware is killing my upload speeds, usually I get 10mbps now I'm getting 0 - .5. PLEASE FIX THIS NETGEAR!
- FURRYe38Oct 20, 2018Guru - Experienced User
How are you tesing speeds? wired or wireless?
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials.What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz.
Any Wifi Neighbors near by? If so, how many?Try disabling the following and see:
If you updated to recent FW v.210, try enabling Daisy Chain. Some have mentioned that this seems to be working in reverse order, enabling means disabled actually. Hoping NG support can have a look at this. So try this out as well.
https://community.netgear.com/t5/Orbi/Firmware-2-2-1-210-and-connection-problems-Skybell/m-p/1649275/highlight/true#M43001Try try this?
