bgeiser286
Aug 29, 2018Follower
Problem with Orbi RBR50 since FW upgrade 2.1.4.16
This router is a direct connect to a feber network; there is no modem.
My normal wired and wireless speeds are usually in the range of 95+ Mbps download and 50+ Mbps upload.
I upgraded th...
Orbi
Oct 20, 2018Star
I am having the same exact problem, downloads are slugish but the upload is zero. This firmware is killing my upload speeds, usually I get 10mbps now I'm getting 0 - .5. PLEASE FIX THIS NETGEAR!
Oct 20, 2018Guru - Experienced User
How are you tesing speeds? wired or wireless?
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials.
MIMO, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
If you updated to recent FW v.210, try enabling Daisy Chain. Some have mentioned that this seems to be working in reverse order, enabling means disabled actually. Hoping NG support can have a look at this. So try this out as well.
https://community.netgear.com/t5/Orbi/Firmware-2-2-1-210-and-connection-problems-Skybell/m-p/1649275/highlight/true#M43001
Try try this?
