webfix4u
Aug 09, 2018Tutor
Problem with Remote Management on Orbi RBR50
Hi
I'm using the Orbi RBR50 system and I'm really happy with it. But when I want to enable the Remote Management in the Orbi app, I get this message: "This NETGEAR device is already registered wit...
Aug 09, 2018Guru - Experienced User
Where did you get the Orbi from? New or used?
I would contact NG support and get there help on this...they'll need to help you get it registered correctly.
